Yea my wife put in some swifty 87 in the car and ever since yesterday its been misfiring. I put some water remover in the gas tank today,along w/ 10 gal of 93 v-power, hoping it will solve the problem. If not i guess i will have to change the spark plugs. If you have any other soloutions please help
multiple cylinder misfire
I have the same problem, but on cylinder #1. They told me to check and/or replace the plugs, check and/or replace the plug wires. Make sure the plugs are gapped right. Otherwise it is a coil pack, or an injector. You might have it put on a scanner and find out which cylinders it is misfiring on, save you some guesswork. Then go after those.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
If it happened right after a fill up I woudl assume bad gas... just run it through and try to fill it up with some good stuff. I have had it happen before car ran like crap till next fill up.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
