when i put my NOSzles on the injectors the fuel rail is going to lay about 3/4" higher..so we were just going to get the fuel rail bolts just 3/4" longer with 3/4" spacers..however..im looking at my engine and it turns out that they are not bolts that hold down the fuel rail..its actually threaded studs that come UP off the block somewhere that the fuel rail slides on to..then nuts just go on to hold it down tight..so its not looking like theres any way to make the 3/4" longer..if thats so..direct port may not be possible because i could take the rail off to put the NOSzles on..but i could not put the fuel rail back on..any help would be appreciated..i REALLY need it..
HELP!!..fuel rail "bolts"
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
Those studs come out, so I don't see any reason why you couldn't just get a bolt of the right thread/length.Matt
1998 Mystic Teal Camaro M5
they do????..how do you get them out if the come up from underneath..also..do you know any of the dimensions on these studs??..i called a dealer and they didnt even know
also..if those come out..then could i just get bolts that are ANY thread as long as i have matching nuts and they are 3/4" longer??..or do they actually thread through something other than just the nuts??
[ February 15, 2005, 06:50 PM: Message edited by: 1DangerousV6 ]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
The stud is just screwed into the top of the lower intake manifold. You should be able to unscrew them to take them out. They may or may not come out easily, but you can work them out.
Once you get it out, find a bolt with the same thread, then you should be able to bolt the fuel rail on.
Edit: Here's a pic of the studs (left it big so you could see them well): http://www.leadingedgesim.com/mkapro...lRailStuds.JPG
I'm not saying for sure you can use a bolt there, but I don't see any reason why you couldn't.
[ February 15, 2005, 07:10 PM: Message edited by: 98Camaro3.8 ]Matt
awesome..really good pic..thanks man..is there a way you can tell what the thread pattern is on the studs after you remove them???..i've called two dealers now and nobody knows!<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Originally posted by 1DangerousV6:
is there a way you can tell what the thread pattern is on the studs after you remove them???Matt
to get the studs out put 2 nuts on the stud.... THEN only turn on the bottom stud and you can back them outwww.turbov6camaro.com
1997 3800 Series II Camaro
ok..i took one of the nuts off and got down to home depot and got the right bolts..they 6MM wide 40MM long ..but i need to know..do those studs that thread into the manifold thread through to hold on anything other than the fuel rail??...if not..i think im all good..if they do..i may have to get longer ones..i dunno<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
ok..i took one of the nuts off and got down to home depot and got the right bolts..they 6MM wide 40MM long ..but i need to know..do those studs that thread into the manifold thread through to hold on anything other than the fuel rail??...if not..i think im all good..if they do..i may have to get longer ones..i dunnowww.turbov6camaro.com
kick @ss..i should be all good then..got the bolts..and i found a company that can provide me with the 3/4" spacers if NOS cant..so those get ordered tomorrow..thanks a lot guys!! [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Those studs do not hold anything else.
On my car, the studs extend about an inch above the nut when it is tightened down. If yours is like that, you should be able to use the same studs. Just put the spacers in. If not, use the bolts.
If you had sent the kit to Florida for me to test like I told you too, you would not be worrying about these things.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
haha..you just wanted a little direct port action ;) ..anyways..thanks a lot for confirming that..my studs only came up about a 1/2" above the nuts..so im gonna have to go with the longer bolts..i actually got a hold of a company who is going to be sending me custom spacers FREE! [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
