Proper Coolant Fill Procedure? - FirebirdV6.com/CamaroV6.com Message Board
  • Proper Coolant Fill Procedure?
    Well, ever since I put my upper and lower intakes back on, my car has been running HOT. The temp never droppes below 195 EVER, even though I have a 180 stat. I think there must be some air trapped in the system somewhere. Anyone know the proper coolant fill procedure so I can try to fix this problem. The heads are probably staying too hot and more than likely is the reason for my detonation problem.
