ok, so my car has been idling 3oo rpms higher than i like, how do you lower the Idle on a 3.4, or is it computer controlled?
idle
also can it be upped or down on a 2k 3.8 m5Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
change the IAC, clean the Throttle body and IAC passages on the intake and check for a vacuum leak1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
dont be lazy and look at your engine yourself, you will see if you can adjust it yourself.
chances are your idle screw wont just tun your idle up 300 rpms. clean the IAC valve with carb cleaner and lube it up good first, if that doesnt work then by a new one.96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
