idle - FirebirdV6.com/CamaroV6.com Message Board
idle
  • idle
    ok, so my car has been idling 3oo rpms higher than i like, how do you lower the Idle on a 3.4, or is it computer controlled?
    -Travis<br /><br />95 Camaro 3.4 M5<br />Pacesetter Coated Headers<br />Catco Cat, <br />Dynomax muffler with custom piping<br />Custom Cold Air Intake<br />B&M Ripper Shifter
    also can it be upped or down on a 2k 3.8 m5
    Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
      Bad Idle Air Control valves?
        can you lower it and raise it tho?
          No. Just go to autozone and buy another one. They charge about $25-$30 for them, new.
            change the IAC, clean the Throttle body and IAC passages on the intake and check for a vacuum leak
            1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
              dont be lazy and look at your engine yourself, you will see if you can adjust it yourself.
              chances are your idle screw wont just tun your idle up 300 rpms. clean the IAC valve with carb cleaner and lube it up good first, if that doesnt work then by a new one.
              96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
