Since I've had my car my motors always sounded odd. I never thought anything of it, but lately people are telling me it sounds bad. The only way I can think to describe it is like something is loose. I'm just curious as to whether or not this is a sign that my motor is going bad...
Is my engine bad?
by loose what do you mean? the more info you can give us the better we can help. also which engine?
Follow me!
Or this
I have some funny noises coming from my car too... sounds kind of like a low-pressure air compressor running whenever the car is going.
I don't really think its a big deal especially since my car has 69000 miles already. If it's not a big problem I would have it checked out just to be safe but dont worry about it.
i'll check the fuses tommorow. I'll try and figure out if it's the AC Compressor or not too. The SES light fuse may have gone out actually, it didn't come on earlier this year (Jan.) when one of my Ignition coils went out. I'll look into it tommorow if I have the time or Thursday (since it's my day off from work).
Just to clarify, don't just look at the AC compressor. That was just my example. Listen all over the engine to see if you can pinpoint at least the general area where the noise is coming from. That will narrow it down and rule out some components. If it's a rattle, make sure you check the heat shields on the exhaust, and look for anything else that might be loose.1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
^^ or the heat sheild could be loose, but he said the engine sounds bad. if the rattle is right under the passenger side seat area its more than likely the cat or heat shield.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
I have the same problem... 12secondv6 can attest to this. Sorta sounds like a dry rattle coming from the belt area97 Camaro<br />160* thermostat, z28 shock/springs, 3\" Magnaflow cat, 3\" Magnaflow catback, LT1 disc/limslip/3.42 rear, SLP CAI<br /> <a href=\"http://www.cardomain.com/memberpage/609893\" target=\"_blank\">http://www.cardomain.com/memberpage/609893</a>
Can you see your SES light when you put the key foward? If so, the fuse isn't burnt (unless there is a fuse that tells the light to come on when there is a problem).
My car knocks like crazy, but it should for having 175,000 miles on it. How many miles does the motor have on it?
[ June 08, 2005, 09:37 PM: Message edited by: Earnhardt132000 ]<b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
