Car won't start...? - FirebirdV6.com/CamaroV6.com Message Board
Car won't start...?
  • Car won't start...?
    I changed wires and plugs today...
    Taylor Spiro-Pro 8mm Spark Plug Wires, Red, 1995-99 3.8L V6 F-Body
    and
    NGK TR6 Spark Plugs, One Heat Range Colder than Stock, Pre-Gapped at .035";
    The car won't start now.
    I need to double check on the firing order, but it goes like this...
    From the driver side to front of car it goes 1 to 6, right to left, right?
    I really don't know what the hell is wrong.
    2002 Silver Metallic A4 Firebird - All Options
    Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
    Your Mom or My Dad?
    need more info than you gave us... does the starter turn? is the battery hooked up? is your fuel pump priming?
      http://home.cfl.rr.com/mkaprocki/Camaro/plugs.jpg
      Matt
      1998 Mystic Teal Camaro M5
        yeah jagerboy, did you not connect the battery back? Is it turning or even clicking?
        1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
          Sorry, here's a little more info. The battery is hooked up, I didn't disconnect it for the plugs. Anyways, the starter turns, the car might fire one or two times, but rarely. Are those wires good for a 2002 or are they only for up to 99?
          I have intake, exhaust, headers... not that it should matter for this. Car ran fine before.
          Your Mom or My Dad?
            Make sure you routed the wires to the correct plugs.
            Matt
              Imagine you are looking from the front of the car back towards the rear.
              Engine is:
              6---5
              4---3
              2---1
              The coil is:
              1
              4
              5
              2
              3
              6
              1991 Z28 - Black L98 350 A4.<br /><br />1999 Firebird - Silver 3800 M5.
                Engine is:
                6---5
                4---3
                2---1
                The coil is:
                1
                4
                5
                2
                3
                6
                Scroll up and look at the previous posts. You'll notice that was already posted. ;)
                Matt
                  Double check which wires go where. Sounds like you mixed up a few.
                  2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
                    double check it.
                      Why are you using the NGKTR6 plugs? Why are they gapped at .035?
                      That is a forced induction mod.
                      Your plugs don't need to be that cold...reducing power and gas mileage like that.
                      You should be using normal heat range plugs, normal gap with stock motor/stock internals, etc.
                      You shouldn't be getting any pre detonation with your current engine. gosh, if you have been maybe your state has funky gas additives? Maybe your getting bad fuel from your neighborhood gas station?
                      01 Firebird A4 3.42
                      Powerdyne @ 6 PSI
                      and other mods
                        Nitrous in two weeks... just getting the car ready for it.
                        Your Mom or My Dad?
                          it's fixed, firing order was wrong.. thanks guys for the diagram.
                          Your Mom or My Dad?
                            ah. say not more.
                            [img]graemlins/burnout.gif[/img]
                            01 Firebird A4 3.42
                            Powerdyne @ 6 PSI
                            and other mods
