Spark Plug/Wire Gurus in here - FirebirdV6.com/CamaroV6.com Message Board
  • Spark Plug/Wire Gurus in here
    I think I crossed my wires. I need the firing order preferrably with a diagram that shows which length wire goes to which spark plug.
    Plugs are fine, I just would like to know which wire goes where from the distributer.
    And I know the firing order is printed on the distributer, but each wire is a different size, and I would like to know which size goes to each plug.
    On the coil packs, it is printed like this:
    1 4
    5 2
    3 6
    Are the spark plugs exactly in that order on the engine? (Left side being passenger with 3 closest to the headlights)
    Thanks a lot!
    -James
    [ June 08, 2005, 12:13 PM: Message edited by: V6viper ]
    no, the order in the engine is looking at the engine from the front odd numbers are on the right even on the left. right front most (closeest to the headlight) is 1 across is 2 back across is 3.. thus looking at the engine from the front of the car cylinders are numbered as such
    6 5
    4 3
    2 1
    as far as which wire goes where, well that depends on the wires, as far as the order that really doesn't matter just make sure what is marked cylinder 1 on the coil matches up with the plug in cylinder 1 and so forth. Firing order makes no difference because this is electrically controlled not mechanically since we have no distributor
    -Brad
    2000 V-Star Custom 1100
    :rock:
      http://home.cfl.rr.com/mkaprocki/Camaro/plugs.jpg
      Matt
      1998 Mystic Teal Camaro M5
        Thanks a lot, I appreciate the help 98.
