99 TB on 97 - FirebirdV6.com/CamaroV6.com Message Board
99 TB on 97
  • 99 TB on 97
    I was wondering about the 99 throttle body. I get the drive by wire and fly by wire mixed up, but I know that they are the same from 96-99, then it switches for 2000-2002. the 98 is still an angled throttle body and the 99 is strait, but the bolt pattern changes. My question is, does anyone have a pic of the 99 TB to see if there is the opportunity to machine it with the correct pattern for a 96-98 and fill in the existing bolt pattern with JB weld or such.
    \'01 Mineral Grey SVT Cobra<br />-former F-body owner
    This was just posted in the Intake/Exhaust forum, but 95-98 A4 TBs are the same and 96-98 M5 TBs are the same. 99 was the first year of electronic throttle control.
    Matt
    1998 Mystic Teal Camaro M5
      No, I dont care about the intake, I am wondering about the throttle body itself for a turbo application. The thread in intake/ exhaust didnt answer my question.
      I am unclear as to weather the 99 is electronically controlled or still has the throttle cable. If it still has the throttle cable, then can the unit be machined, or can an adapter plate be made, that will allow it to be used.
        2000+ is electronically controlled
        im sure you could make a plate, but i don't think to bolt patterens are that far off..... we need a side by side picture
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          Then you're reading the wrong thread in intake/exhaust because I am talking about the throttle body.
          That is incorrect. 99 was the first year of electronic throttle control. A 99 throttle body simple will not work on a pre-99. See my post above for compatible throttle bodies.
          Here is my 98 TB on a 99+ spacer. The bolts on the bottom line up, but the top one is off. http://home.cfl.rr.com/mkaprocki/Camaro/throttle.jpg
          [ November 20, 2004, 12:46 PM: Message edited by: 98Camaro3.8 ]
          Matt
            oh that right [img]graemlins/twak.gif[/img] [img]graemlins/stickpoke.gif[/img] [img]graemlins/slap.gif[/img]
            we need to switch the upper intake not the tb we need OUR TB to mount to there upper... not the other way around..... took me a second to remember
              ok, if its electronically controlled it doesnt matter. too much other crap to mess with to make it worthwhile.
              still not seeing the thread in intake/ exhaust your talking about, unless its under some misleading topic... or Im just staring at it and missed it. Based on the searches I did I got conflicting info about the 99. Thanks guys.
                you need a upper intake from a 99 and up car........ its the only way to do the make your TB work on it
                  [quote]Originally posted by 98Camaro3.8:
                  oh hell thats all? **** you could drill and tap that in 30mins and have it installed !!!!
                    Viper, you're forgetting that it's also electronically controlled. You're gonna have to do a hell of alot more than just bolt up the TB.
                    Matt
                      not if i bolt my 97 TB on the 99+ intake !!!! just have to make that top bolt work [img]graemlins/banana.gif[/img] [img]graemlins/banana.gif[/img]
