I have read a top of posts, many have said they had an exhuast leak somewhere. Where do you have the leak at? And were they easy fixes?
Another note: Today i started up my ride when it was cold out, i happened to look under the car and i see white smoke coming from the connection of the Flowmaster and the S-pipe,. This sucks.
Most exhaust leaks are either at the headers or EGR valve. When I had just the loudmouth it leaked at the s pipe but I JB welded it shut [img]smile.gif[/img]
\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
jb weld worked? its completly sealed huh. im gunna try that. i was origally thinking of welding some **** oghet or something but i havent had a chance to look at it entirely. thnks dude
most leaks are at the egr or the header/manifold gasket or the y pipe. jb weld will not seal up any of the mentioned locations because it is simply too hot there and the jb weld will burn off
