blinker problem - FirebirdV6.com/CamaroV6.com Message Board
blinker problem
  • blinker problem
    my left blinker doesnt blink. when i turn it on to use it, it just stays on. my right blinker works fine though. What couild the problem be?
    jp
    1998 Artic White M-5<br />K&N filter, whisper lid, undercar ramair, Dis-4, MSD 8.5mm SC, bosch plat 4+, BMR STB, Jet stage 2, Poly tranny mount, B&M Ripper, 1le DS, 1le Pan hard rod and lca\'s, LSD, hi-flo cat, flowmater, Kumho 255/50/16, and centerforce dual friction clutch.<br />(E.T. ?, but I beat a 15 sec flat integra by 3 cars in 3rd gear and pulling)<p> <a href=\"http://www.geocities.com/fbodies9870\" target=\"_blank\">http://www.geocities.com/fbodies9870</a><p>*****CAR TOTALED*****<p>2002 Artic White z28 A4 Loaded
    One of your bulbs is out. Turn the blinker on, and look on the outside of your car to see which blinker stays lit. The one that's not lit needs to be replaced.
    1997 Y87 Camaro with a motor and some stuff.
      sped214 is right. The one that is staying on is the one w/ the problem. It will either be the front or rear blinker. They're real easy to fix. If its the front one just look under the car and there is a panel w/ 2 screws. Unscrew it and it flaps down, then just twist the housing to the bulb and it pops out. In the rear it s pretty much the same way just move the carpeting out of the way.
      1999 Firebird (black)<br />Y87 package<br />Whisper lid<br />FRA<br />Raised airbox<br />K & N Filter<br />Removed MAF screen<br />180 thermostat<br />3\" catalytic converter<br />Cat-back exhaust<br />Flowmaster<br />\"Fool you can bet, that I can dance underwater and not get wet\"
        thamx alot [img]smile.gif[/img] . I thought it was some big thing, but thats no big deal. [img]graemlins/burnout.gif[/img]
