i think i have a bad ground cuz my right headlight is dim and the right turn signal in my car is lighted up a lil bit and one of my right taillight bulbs is on when its not supposed to be............so i dont know hat im supposed to do to fix this. Thanks
Bad Ground for headlight I think......help
Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015Tags: None
You will need to use ALLdata, Haynes, or something else that will have a schematic of the wiring diagram for the lighting system for your car. The grounds are numbered and if you use alldata, you will be able to look up the individual ground numbers.
Jim
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
