When i am driving, when my RPM's reach 2k, my car starts to studder and will barely speed up. I bought a fuel filter, but havent installed it yet. What else could it be? Or do i have a good chance that it is the fuel filter? It only does it when my car is in gear and moving. Thanks in advance.
--Fierdon
1995 3.4L A4 Firebird White w/T-Tops *SOLD*<br />**NEW CAR**<br />2004 White Cavalier Coupe<br />2.2l ECOtec 5 speed
Does the engine seem to struggle? Could be a clogged cat...
Hey, does it free rev in neutral and park (or if a standard, then just neutral)? Does it go fine until you hit about 2K rpms and then shudders really bad? Does it make you think it's the tranny slipping? how about after you pass 4K rpms, does it clear up? If so, these were my exact same sypotoms. It's most likely a miss. I changed the fuel filter, and made no difference, so it could have been bad gas, so I got some gas treatment, still no fix. I was worried it was the injectors, but the treatment was supposed to clean them. I decided since it was gettin fuel, I needed to go back and check the spark. I was getting little to no spark on 2 coil packs. I changed all 3 coil packs, the plugs and the wires.
It's runnin great now.
<blockquote>quote:</font><hr>Originally posted by silvachris1: Hey, does it free rev in neutral and park (or if a standard, then just neutral)? Does it go fine until you hit about 2K rpms and then shudders really bad? Does it make you think it's the tranny slipping? how about after you pass 4K rpms, does it clear up? If so, these were my exact same sypotoms. It's most likely a miss. I changed the fuel filter, and made no difference, so it could have been bad gas, so I got some gas treatment, still no fix. I was worried it was the injectors, but the treatment was supposed to clean them. I decided since it was gettin fuel, I needed to go back and check the spark. I was getting little to no spark on 2 coil packs. I changed all 3 coil packs, the plugs and the wires.
It's runnin great now.<hr></blockquote>
Yes it does free rev in park and neutral. And if i get above 4k rpm it stops... how much would it cost for the coil packs? and are they easy to install?
When i am at cruise speed (2krpm) it is fine, if i give it just a little gas it starts to do it. I have to step hard to get it to speed up. Thanks again.
[ October 15, 2003: Message edited by: Fierdon ]</p>
<blockquote>quote:</font><hr>Originally posted by Fierdon:
<hr></blockquote>
I got one coil pack at Advance Auto (I got an AC Delco pack) it was $38.99. I got the other two at autozone when the first one didn't cure the problem. They were $19.95 a piece, and I think the brand was WELLS (though I've never heard of them. The plugs were like $5.60 a piece, for AC Delco Iridium Plugs or something. Then the wires were like $20-35 bux, I'm not sure how much though.
If this doesn't solve the problem, it could be the ignition module. I think Autozone has them for $99.
And then if that doesn't fix it, then its not spark, it's gotta be fuel. Could be the filter, or the pump or who knows what all. I'd say, go ahead and change the fuel filter while you're working on the car, it's not expensive and takes less than 5 minutes. Mine was nearly clogged off at 44K miles.
Well, i changed my Fuel Filter and it still does it. To get it checked would cost me $50. Oh, and yes it does bog down at part throttle. Thanks again for the help.
Did you install the plugs/wires/coils too? And it still does it? If it's still not getting spark, then it could be the ignition module. If that's not it, it's prolly fuel dilevery. Since it's not your filter, it could be the fuel pump, or the injectors. If not, then I dunno.
