Tune up,,,plugs and wire question - FirebirdV6.com/CamaroV6.com Message Board
  • Tune up,,,plugs and wire question
    My 3.4 is due for a tune up. What type of plugs and wires should i use?? part numbers from like jegs or summit or wherever you get your stuff from would be helpful. thanks in advance
    1995 Camaro 3.4L<br />dynomax super turbo muffler<br />SLP CAI<p>It\'s red so it must be fast!!!
    I don't have part #'s, but for plugs, Bosch or AC Delco Platinums (if you're just doing the everyday driving :D ), although I'm a cheapskate, so I favor the Boschs ($1.99 ea).
    As to wires, I have Bosch, had them on my 3.4, no problems with them. They're 7mm wires, though, if you want 8+mm wires, stay away from Accels. I had problems with their wires, and other people have complained about them also. Taylor and MSD are the other main ones I can think of. If you want to do coils, the Accels are the only hi-perf, and those do work well, and add noticeable bit of pep to the old 3.4. Hope that helps.
      ngk plugs, borg-warner wires
