Power/Electrical System problem.. - FirebirdV6.com/CamaroV6.com Message Board
  • Power/Electrical System problem..
    okay. i had a problem with my alternator. i replaced that.
    the alternator is a 160amp alternator.
    when i first started it up, it was all good.
    but now, it sits below the 13 mark. when idling, its on the edge of the yellow. when i hit the brakes, it has a power drain. when i put it into nuetral, its like the alternator stops working. same with park. when the car is htoter, it APPEARS to have a lesser voltage reading.
    i also have a 400W amp drawing power, but thats never caused a problem.
    okay, those are the problems.
    what do you think could be the problem?
    a wire is burnt somewhat?(i've checked these, and they don't appear to be bad, but i'm probably missing something)
    a bad ground from the battery?(i've heard that its sometimes too small)
    how i have my system hooked up?(i have it into that red box. i've heard that it might be too much of a strain on the power wire from the battery going into that. since its a smaller guage or something.)
    any other suggestions? or possible fixes?
    \'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
