MSD 6A vs DIS4 - FirebirdV6.com/CamaroV6.com Message Board
MSD 6A vs DIS4
  • MSD 6A vs DIS4
    is there any advantage to using a DIS 4 over a 6A?
    or will the 6A even work on a car equipped with a DIS?
    -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
    no the 6a will not wokr on a DIS car.. only the DIS will.
      I got another question along these lines. I saw two DIS-4 boxes , one was the High Output DIS-4 and the other the normal one. Whats the difference? Can we run either?
      2001 Pewder Firebird V6 A4 <br />Custom Turbo Kit Details On Site<br /> <a href=\"http://www.cardomain.com/id/njp98\" target=\"_blank\">http://www.cardomain.com/id/njp98</a> <br />Best 1/4 time NA - 15.224 seconds @ 87.55 MPH
        I called MSD about this and they specifically said that you should not run the HO box unless it is a RACE ONLY application.
          yea, i looked at them before, and i dont know if its the volts or what, but one of the numbers was higher.
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
