when you undo the nuts that hold down the fuel rail and pull it up..the injectors come up with the rail right??..so (on 3/12..woohoo!) the shop should easily be able to pull that up and put my NOSzle bosses in where the injectors used to go right?..thanks!
injectors with fuel rail
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
Correct. The only problem I see is that the injectors go in at an angle. With a 3/4 inch extension on the end of the injectors, the legs will not only he higher up, they will be a litle further back. I am guessing the injectors are at about a 15* angle. Doing some basic math tells me that the legs will be about .2 inches further back, or just less then a 1/4 inch. I hope this makes sence.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
hmmm...i've heard you can just pull straight up and the whole thing will come out though
As long as you pull evenly, it should pretty much just come right up. Otherwise, just start on the front or back, and pull up the first two, then the next 2 back, and then the last 2.
You really only need it to come up about 1/2" or so to get the Oring out of the bore, so the whole rail doesn't have to move all that much. If you pull them out a pair at a time, you shouldn't have to worry about bending the rail I don't think.
When I pulled mine out, it as pretty tight in there, so if it doesn't come out right away don't think you're doing something wrong. Just take your time and it will come out fine.
REMEMBER
Take compressed air and blow out the areas around the injectors before pulling them out!1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
When i said correct, I was talking about pulling them out. They come out pretty easily.
The other thing I was talking about was about when you go to put them back in with the Nozzles. It is just something to think about.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
ohhh i got ya...i was looking at where the bosses would actually sit..the metal of the manifold where they will sit on is actually angled inward like the angle you were describing..you can see it here on Magnus's site:
http://www.dxsoftware.com/magnus/
..go to "Intake P&P" on the right side..thanks man..and very good point! [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
