When I slow down, I can hear a quiet clicking noice coming somewhere from around the rear right wheel. Does anyone know what it is? Is it the drumbrake? Please help me out... Thanks
Clicking Noise
do you have the stock hubcaps or rims on the car?Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
I have this same problem to...! but i have hubcaps on the car right now... but the clicking noise on my car is coming from the Front LEft<b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
I have the caps also and the reason that I asked the question is, if you have the caps then it is probably a loose lug nut on the cap mine work themselfs loose and if I am going slow enough annd have the window down I can hear them clicking I then get out and tighten them up and they are good for a while. as for the rims I have no clue.
AllTheCoolNamesAreTaken where in CT are you? I am in watertown.
[ June 24, 2002: Message edited by: vampyr ]</p>Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
If i is coming from the front left, that is where mine was ticking when my Pads where starting to get low and the ABS INOP light and Low trac light would come on. For me it meant new pads. I'm not sure about rear.<a href=\"http://www.saintsworth.com/z06\" target=\"_blank\">\'02 Corvette Z06</a>
Yeap, rocks will do it. But, something worse, is when a small piece of metal gets in the tire. It can take forever before it finally works itself out of the tire. So if you don?t find a gravel in the tire, then it may be a piece of metal or something of that nature. If so, you can run your hands over the tire to find it, but be careful. Cause you can really slice your hand if you rub over it to fast. :eek:2000 V6 Camaro(bought brand new)
5 speed
Project: Unreal
Several Mods..:naughty:plus Nitrous=WEEeee:banana:
2007 Suzuki GS500F :D
Daily driver
2007 Chevy Aveo 5
Mods K&N air filter:excited:
www.guardiansworlds.com
