If the timing chain broke - FirebirdV6.com/CamaroV6.com Message Board
  • If the timing chain broke
    not my car but if it broke, would it make a pop sound apound breaking and the car would studder when letting off the gas and die at lights and such?
    2000 3.8 A4 Pewter Camaro
    NO YOUR CAR WOULDN'T RUN AT ALL
      Not only would it not run, but a piston would very quickly meet a valve.
      Matt
      1998 Mystic Teal Camaro M5
        thanks. i should have known that right off. im at my moms work now cause her car is all sorts of messed up it looks like and i was just brain storming before i left the house. thanks guys
          what kind of car and motor?
            97' Dodge Neon w/ 113,000 miles on it. dies and or stutters when you let off the gas and a pop when it started, knocks, white smoke from exhaust, steam from behind motor, and bubbles in the radiator. blown head gasket IMO :(
            timing belt looks fine but slightly loose but not bad
            im going to tow it to my house and take it apart for inspection. hopefully it didnt hydrolock cause i dont want to take the bottom end apart if i can help it :\ well see, after that, im going to tow it to my school so i can put it back together in class :D
              do a compression test, I am leaning towards, 90% chance of blown head gasket, from the symptons and neons are well known for blown head gaskets.
                yeah, my teacher did one last year so it should go over well. i plan on to doing a compression and cylinder leaking test [img]smile.gif[/img]
                i plan on replacing the top end anyways because of the mileage and plus it has been ticking/knocking for months now. never tought about a blown gasket tell now. just figured i was flotting a lifter or something like that you know
