Every time i start my car the Change oil light comes on, for appox. 2-3 mins I have checked the oil and its fine, and just had it changed 1000 miles ago. Anyone have any ideas what could be making this lite come on?
Need help
Dirty oil?
Did you completely drain all the old oil out?
Personally, I'd just reset the light, and call it a day. I dont pay attention to that light....the only light that I look at is the SES.
All others can have the fuses pulled.
Reset the light. If the light returns in a sort time it suggests that you have some sort of a problem. Then, scan for codes.2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
Hold the odometer reset button down as you turn the ignition to the ON position (you don't have to start the car if I recall correctly). Hold the button down 'til the light flashes & goes out. You will find the instructions on how to do this in your owner's manual, as well.2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
