Weird noise plus fluid ???? - FirebirdV6.com/CamaroV6.com Message Board
  • Weird noise plus fluid ????
    Everytime I accelerate, whether it is slow or fast I hear a strange noise almost like a squeal. It appears to be coming from my drive belt/pulleys. I ran a wet towl over the belt when the car was off and there was a strange fluid on the belt. I've cleaned it off several times but it keeps happening. I plan on replacing the belt this week but I think the power steering pump may be leaking some fluid. There is no visible leaks and no fluids are found under the car.
    The only time you hear the noise is when I accelerate or rev the engine but mainly when I accelerate. It has become more consistant and seems to happen areound the 1.5 - 2 K RPM range. It happens in this range the most and the loudest. Any suggestions, ideas, etc. ANy help would be appreciated. Thanks in advance.
    1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
    if there is oil on the belt then that is what is causing it to slip so dont bother with a new belt until you know where the leak is and fix it. good luck.
    white 1996 camaro 3800: flowmaster American thunder cat back. hypertech 160* stat, and manual fan switch
