It is on its way out. It will go half way, stop, go a little farther 5 minutes later, stop, and so on. Is there a quick fix for this, or should it just be replaced? Anyone got one to get rid of for cheap?
Power Window problems
Sounds like your motor is on its way out.
One question though: when the window DOES go up a little, is it going full speed or is it slow?
If it's full speed, it may be an electrical problem. (Switch, wire, connector on the motor, or the motor itself)
If it's slow, It's most likely the motor.
If you feel competent enough to do the repairs yourself, It's not that difficult.
Do a search for "window motor" (no quotes) and that will tell you how.
If you get your door panel off and the tracks look all gunky, you may need to clean those as well. You should be able to get some grease from Pep Boys or wherever. DONT use regular grease or oil... it will disolve the plastic parts on the window rider.
Good Luck!
-BrianMaroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
<blockquote>quote:</font><hr>Originally posted by Jessie:
It is on its way out. It will go half way, stop, go a little farther 5 minutes later, stop, and so on. Is there a quick fix for this, or should it just be replaced? Anyone got one to get rid of for cheap?<hr></blockquote>
Dont feel like the LOne Ranger its happened to a lot of us. Replace the motor. Go to Autozone or somewhere. Its too expensive for the dealer.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
I had the same problem.
Got the motor replaced for $150. Shop around a little, cause every place has different prices. But spend the money, it's really worthy it; especially when you have a drunken friend ready to throw up while driving on the freeway.... [img]graemlins/crybaby.gif[/img]Sunny Cali, T-top is the way to go! \'96 V6 3.8.
i havent got around to changing my motors, ive bought them but havent put them in, i wish i did have manual windows, i worry too much with autos with them scartching the windows and messing up tintCamaro 95 3.4L M5<br />Flowmaster 80srs<br />Catco High Flo Cat<br />Slp CAI<br />Prime wheels
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...4 weeks ago
