Hey...
I was wondering what the shape of the TPS connector was on a 1999 3.8L is it round or flat? Will the tps-tec from a 3.4L work with the 3.8L?? All I know is that the tps from a 3.4L is round.
I know on a 96 3.8 it is a flat 3 pin connector. The only other one out there I know of is a 3 pin triangular connector which I would assume is for the 3.4!
from the description: 102017 TPS TEC Throttle Enhancer for all GM engines with round TPS Connector 1992-2002 Not designed for DRIVE BY WIRE applications.
i believe this is the right part for 1999's: 102018 TPS TEC 3800 Engines 97-02
Has anyone used zzp gt1 cam if so is it worth the money and time
