~13 volts at idle when cold
~12 volts at idle when warm
~11 volts at idle when warm and system is on full blast
I have a 1 farad cap installed in the hatch, and that helped a good bit keeping my needle from dipping into the sub-10's on heavy bass notes.
If you've got the air on you can figure on .5 volts less than the above figures, and headlights draw another .5 or so. Of course, these are all only at idle... blip the throttle and you're back up to 14. So unless you do a lot of stop-n-go you should be fine.
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
