I have underdrive pullies on my car and am about to put my amp and subs back in. I was going to be adding a capicter this time but with the underdrive pullies the battery undercharges as it is. I am wondering if I can just get a high output alt and solve both problems. will a HO alt charge more that idle that the stock alt?
HO alt with underdrive pully question
95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>Tags: None
yes but with underdrive pullies the whole point is to slow the alt, water pumpp, AC units down to reduce parasitic drag. so a HO alt would be bettre than what you have now but it would still not produce as much power as a HO would with a stock pulley.1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
yes, most stock alts dont put there power out at idle... you can easily see this especially in my car... if u rev the engine, you can see the voltage raise and go back down...
HO alts usually put maybe like 120 at idle, for a good 180 amp altWhite 1998 3.8L Camaro
Home Ram Air / Free Flow Intake
Drilled / Slotted Rotors with black painted Calipers
as long as it helps keep the voltage up witht he underdrive pullies it is fine with me, even if I haft to get a capiciter for the amp so it will not drop at idle.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
A capacitor won't help you at all. Just get the HO alt. Most of them do close to their rated power by 1500 rpms. The stock alt puts out a max 105 amps and thats at almost 3000rpm's(3.8l but should be the same with the 3.4)2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
where can I buy one fairly cheep? I would like to put it on when I put my headers on if I can95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
