3.4 Stuttering/Hesitation - FirebirdV6.com/CamaroV6.com Message Board
  • 3.4 Stuttering/Hesitation
    Okay, a bit of a mystery here. I have a sort of a stuttering in almost every gear, throughout the RPM range. I have replaced my Plugs, Wires, Coil Packs, and my ICM. I dont have any clue what it could be.
    I drove around with a fuel pressure gauge attached, and fuel pressure remains constant at idle, and jumps up when I accelerate like it should. So fuel pressure is fine. I also replaced the fuel filter, so flow is good as well.
    I'm at a complete loss. I cant tell what it is, i've done everything. The car seems to idle good, right where it should. lol. Any help you guys can give would be awesome. Thanks.
    -- Mike
    [ July 30, 2003: Message edited by: equalizer ]</p>
    1995 Blue Chevrolet Camaro <br />Dynomax Exhaust, Custom CAI w/K&N, Throttle Body Bypass, ACDelco Plugs/Accel 8mm Wires. Indiglo Gauges. BMR Stut Tower Brace, ASP underdrive pulleys, BF Goodrich g-Force T/A KDW\'s around. <br />AIM: STMIKEK
    injectors? bad tank of gas? intake/exhaust leak, restricted cat?
    Know anyone that can hook it up to a scanner to check sensor readings and possible misfires, new doesn't always mean good
    [ July 30, 2003: Message edited by: camarofan ]</p>
      i seem to say this alot but, injectors? Check the plugs, and see what they look like. I just don't want too see you go through what i did, $1000 in tinkering and no fix, till i finally stumbled across it.
      1995 Camaro 3400 SFI V6 M5<br />Custom CAI|FloPro Exhaust|Mobil 1 sythentic|Yokohama T4\'s| 5% Rear Window tint, 35% front| Hockey stick side stripes|Indiglo Gauges|Custom Painted Interior<p><a href=\"http://www.cardomain.com/id/3400camaro\" target=\"_blank\">www.cardomain.com/id/3400camaro</a>
        try a tuneup and fuel injector cleaner ;)
        [ August 02, 2003: Message edited by: BadLiLBowtie ]</p>
          i have a similar prob. with my car. I have had the wires, injectors, fuel filter, plugs, and coil packs tested. One of the techs at the dealership told me it might even be a weak valve spring. I have a feeling he is right. I put lucas upper cylinder lubercant in and i dont get a miss for about a few weeks. and then its back again. This is just one more idea of what it could be.
          99 firebird A4<br />W68 package, Y87 package,SLP ram air H.O.hood,Whisper lid,kn filter,Borla 3in. adj. cat back smallest plate, 180*powerstat, removed maf screen, 3 in. cat,ngk plugs, nitto 450 245/50 tires
            I had the same problem except it was only under load - it ended up being one of the coil packs... it tested good, but when it got hot it would short out sometimes.
            Other then that I think I would try the fuel system - injectors, pump, filters, etc...
