Well... finally removed A/C perhaps it will help install too. - FirebirdV6.com/CamaroV6.com Message Board
  • Well... finally removed A/C perhaps it will help install too.
    First off let me say that my A/C is busted and that is why I removed it.
    My car is a '97 Camaro RS. This modification was not as simple as you might think since, according to parts stores no '95+ came without A/C. Anyhow more than just a shorter belt was needed... just a minute of headscratching and a bunch of PITA bolts for the compressor removal. As the hanes manual describes, the accumulator and condenser were straight forward to remove. Anyhow, here is a comparison of how the serpentine belt was routed versus my new route. (I made sure all accessories ended up turning the same direction too.
    http://chillcat.fortunecity.net/stock.jpg
    VS
    http://chillcat.fortunecity.net/modified.jpg
    I tried to obtain an 80" belt for the new one but only could find 80.5" it is slightly looser than I'd like (slips back a little) but the alternator is charging just as well and the engine runs just as cool as before. I am considering searching out an 80" belt... I'll see if the belt doesn't settle after a little bit. As it is there is no unwanted rubbing. No noticeable difference in performance of course... but I bet it will help a little on the track. It removed ~40 lbs from the front of the car and probably freed up 1-2 Hp.
    Edit: I did not modify the heater core as it is overly labor intensive for very little purpose. As it is My HVAC system is still 100% Functional minus the A/C.
    [ October 27, 2003: Message edited by: ChillPhatCat ]</p>
    Black \'97 Camaro RS <a href=\"http://chillcat.fortunecity.net/blahblah.html\" target=\"_blank\">See Pics</a> 3.8L, 5 Spd, Disc Rear, Hurst short shifter, MAF Screen Removed, RK Sport Headers, 3\" Cat, 3\" FM American Thunder Catback, Compcams .512/.507, (2x)275/40/17 Khumo 712(front) (2x)285/40/17 Good Year F1 GS-D3 (back).
    Yea, my little bracket that holds the compressor to the engine snapped where it goes thin around it. It took me a week to ship out a new one and then I thought my compressor was broke from all the grinding it did into the engine. But it still works ;) so I don't gotta get into the hassle of removing it, i'm glad, and those suckers are expensive too.
