84 camaro problems.... - FirebirdV6.com/CamaroV6.com Message Board
  • 84 camaro problems....
    this isnt for a v6......but this is the best forum i know where i can get help.
    Car is a 84 camaro 5.0
    i changed the fuel filter the egr valve the mixture control solenoid and done changed the carb gasket out. It turns on it idles fine but when i push the gas to accelerate it dont stall but it acts like it dont wanna give it any gas . i can drive real slow but as soon as i push it to go faster it dont wanna go i know its a fuel problem that has to do with electrical stuff. me and my dad are both puzzled.
    [ July 31, 2003: Message edited by: CAMAROWITHBASS ]</p>
    My car has GPS trackin\',traffic alert,its own phone #,PS2,screens. And What da H3ll,When I Turn da key it says \"You\'ve got mail\"..... <br />I swear and promise.. I\'ve had more cars then Charlie Thomas.. bounces in a Monte\' that hopped.. Pimped old skoo Blazer on Chopz, Today Its a Camaro at all da plya spots.
    It sounds like you're talking about a carbureted car. If that is the case, check the needle valve and float level in the float bowl. What you're describing is what happens when the float level goes to hell or the needle valve goes bad. Enough fuel to start and run the engine at very low RPMs seeps through, by anything faster drains the float bowl. I once got stuck out in the sticks and drove a 67 Valiant for 30 miles at 10 MPH because of the exact same problem.
    <b>Mike</b><br /><a href=\"http://www.cardomain.com/id/mcjoslyn\" target=\"_blank\">2001 Camaro</a><br />Light Pewter Metallic Convertible<br />AU0,A31,C60,DG7,F41,GU6,K34,L36,M30,T82,T96,UN0<p ><b>If it can\'t be expressed in figures, it is not science; it is opinion.</b>
      yes it is a carbureted car
        have you rebuilt the carb yet? any codes? The tps should be looked into. WHen the carb is off, shake it, see if you can hear it "rattle" If it dont, you'll need a new one. Or, when rebuilding carb, whicj\h can be done while still on car, take tps in & have tested for free :D
        Also, included in the rebuild kit is a new throttle/power valve. when you accelerate, it oushed on the plunger on the top left of the carb. If the seal on the plunger is crapped out, it will also affect off idle performance. While you're at it, check all vacum hoses going to the carb too.
        Anything else? ;)
        2013 Ram 1500 Big Horn
        94 comero 3.4
          could it be the ECM?
            <blockquote>quote:</font><hr>Originally posted by CAMAROWITHBASS:
            could it be the ECM?<hr></blockquote>
            It could be, but the only way to check is take it to a dealer. If it is bad, then either the PROM is crapped, or the mainboard.
            94 comero 3.4
              What about a clogged exhaust?
              If the cat has melted down, it can cause massive backpressure.
              2002 CAMARO \"RS\"<br /> 3800/M5/Y87
