Im at 112,450 on my 95' 3.4.. I wanted to sea foam before my oil change, but its already past due and needs to be done 1st.
So when should i do the sea foam treatment? Also whats a good oil to use ?
Thanks.
-95\' Cayenne Red Camaro 3.4<br /><a href=\"http://www.cardomain.com/id/kurupt95z\" target=\"_blank\">Pics and Mods </a>
First, which sea foam treatment do you want to do? since you're talking about the oil, i can only assume that you're planning on putting some in with your oil before you change it. If that's the case, how many miles past due are you?
______________________________________
1994 Medium Quasar Blue L32 M5 Camaro
Eibach Pro-Kit
PFC Carbon Metallic brake pads
KYB Gas-A-Just shocks
K&N filter
Dynomax rear section with SS tips
*wrecked, airbags deployed, still drivable*
