Car studdering, mechanic stupid, help! - FirebirdV6.com/CamaroV6.com Message Board
  • Car studdering, mechanic stupid, help!
    So when my car is in any drive, even reverse, it studders, you can even feel it in the seat. It's not a bad noise or anything it just studders, du, du, du, du and when it drive (it's automatic) it doesn't shift well in gears. It's at a shop now and the idiots can't figure out what's wrong. He was like I think it's the spark plug wires, but I just got brand new plugs and wires 5 months ago, they can't be bad right? Any clues on this????
    could be a coil pack, also check to make sure all plug wires are on tight.
    <a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
      <blockquote>quote:</font><hr>Originally posted by Chris Hacker:
      So when my car is in any drive, even reverse, it studders, you can even feel it in the seat. It's not a bad noise or anything it just studders, du, du, du, du and when it drive (it's automatic) it doesn't shift well in gears. It's at a shop now and the idiots can't figure out what's wrong. He was like I think it's the spark plug wires, but I just got brand new plugs and wires 5 months ago, they can't be bad right? Any clues on this????<hr></blockquote>
      heres things to replace
      plugs, wires, coil packs.
      it has to be one of those 3 things. i'm not sure how the coil packs are on fbodies, but on my DSM theres 2 separate ones that control the cylinders in this order
      [41] [23]
      then from there they're connected to a transistor pack.
      you can test the coils. get a chiltons manual, they're you're best friend [img]smile.gif[/img]
        mine does the same thing. I followed everyone's advice.
        The plugs, wires, and coil paks were changed. It ended up being none of the previous. I suggest you take it to a different mechanic that knows what they are doing. Randomly fixing things is expensive, trust me!
        Soon to be Mommy!<br />2005 Honda Pilot EX-L
          Chevy dealership, they cost more but they'll do it right and stand behind the work.
          \"Since I started working, every single day has been worse than the day before, so that every day you see me is the worst day of my life\"
            yes my car does that as well more of a pulling though i got it scan for codes cause check engine light came on on thursday n they said it was due to spark plugs n wires n coil packs i replace all but coil packs now it is pulling even harder? pulls (studering)? but the ****** up thing is that half my city is on fire right now n i can't do a damn thing but the coil packs? could this be the reason? n should i just order the performance one's off like ammperformance?
              silly question
              but are your plugs gapped correctly?
                oh btw
                for the coil packs if you're gonna buy em
                get them from autozone. they have a lifetime warranty.
                  i would hope i paid i shop..lol....n so there isn't a real big diff from buying "performance" ones n just some from autozone?...
                    <blockquote>quote:</font><hr>Originally posted by Up2NoGooD619:
                    i would hope i paid i shop..lol....n so there isn't a real big diff from buying "performance" ones n just some from autozone?...<hr></blockquote>
                    not really imo
                    i'm sure theres some one on here who will say that "performance" coil packs will make your car run 2seconds faster than stock though [img]tongue.gif[/img]
                      Im having what sounds like the same prob as this (sputtering) The codes it was giving said misfire in 4th cylinder, and then something about EGR valve position sensor. I looked everywhere online for this sensor and nobody seemed to have one for my Firebird. So yesterday i go to the Pontiac Dealership. The parts guy there says my car doesnt have an EGR position sensor. So why in hell did the code say i needed one? pfttttttttttt on my way walking out, i asked a mechanic about what i learned.He said the EGR on my car is computer controlled. He told me to replace my plugs/wires and check the coil packs...
                      1996 Arctic White Firebird , Auto , stock <a href=\"http://www.cardomain.com/id/smokeyinswf\" target=\"_blank\">http://www.cardomain.com/id/smokeyinswf</a>
                        [img]graemlins/fluffy.gif[/img] I just got out from being under my Firebird for an hour changing 1 single spark plug wire ! :( Well in my 96 Firebird the plugs arent exactly easy to access. I had to go from underneath and everytime i got the wire on i tried getting behind the wire head and push it on( NO room!)it would slowly slide off. I got a little irrate then paused for a smoke break(the good kind!)and then went back underneath it with a whole new attitude :D first try slid on and then got the metal cover back on.. With all those symptoms i was having with the sputtering and codes saying misfire on 4th cylinder, bad EGR valve, i replaced 1 plug wire and she runs excellent !!!!! Looking over the bad plug wire i could see really nothing wrong. Until i spotted a flat spot due to a melt(really small) i squeezed it and out came the internal wire :D Needless to say my Firebird is running better than ever !!( i have only had it 3 weeks and apparently had the problem the whole time)For all those with sputtering probs, check your wires !!!! Mine appeared new and kinda weird that the bad wire caused 5 codes to show up on my check engine light.Well now im off to cruise and hopefully take out a few ricers along the way !! [img]graemlins/rofl.gif[/img]
                          So, the shop said it ended up being my fuel injector in my #5 cylinder. Anyone know anything about those problems. It's like $140 to replace it. And they said when one goes bad you pretty much are guaranteed the rest are bad as well. This true??
                            <blockquote>quote:</font><hr>So, the shop said it ended up being my fuel injector in my #5 cylinder. Anyone know anything about those problems. It's like $140 to replace it. And they said when one goes bad you pretty much are guaranteed the rest are bad as well. This true?? <hr></blockquote>
                            Sounds like they trying to upsale parts to you.
                            1999 Pontiac Trans Am M6 Far from stock.....
                              smokeyinswf, i know what u mean about gettin the plugs on the bottom. i forget which # they are but they're damn near impossible to get. the wires i didn't really have a problem with though...
                              mcG<br />aim=endlive<br /><a href=\"http://www.cardomain.com/id/endlive\" target=\"_blank\">97 firebird</a> ~ wrecked
