IMO, the climate would probably dictate which weight oil I would use.
5w is for colder climates, 10w is for warmer climates. I use 10w-30 in my Camaro all year around (because it doesn't get used in the winter). While I run 5w-30 in my truck all year around. Both those weights are manufacturer recommended.
But if I was to drive the Camaro (and that's a BIG if) in the winter, I'd change to a 5w.
Any of those brands are good enough to use. They all have to meet spec.
Becareful if you decide to switch to synthetics with high mileage, heard they tend to piss off your gaskets. I use Valvoline Maxlife ( i have 120000+ miles ).. but it really isn't a BIG deal on what kind you use, its how often you change it. As long as you change it every 3000 miles and use half decent stuff, you'll be ok [img]smile.gif[/img]
RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
<blockquote>quote:</font><hr>Originally posted by Red94Camaro: Pennzoil is one of the worst oils you could put in your car. DO NOT USE IT. I've seen what it does to engines.<hr></blockquote>
can someone comment on this? my family has used penzoil for years... ever since i can remember, and i can not remember one engine problem ever.
if someone can say something about this ill change my oil type immediately
8 hours ago
