There is coolant along the bolts of the oil pan on the passenger side. Nothing appears to be leaking. I can see anypath of where it could come from. Hoses look fine, thermostat looks fine. The only thing I cant see under the car is the water pump. where could it be coming from?
coolant leak?
Look on top of the engine of a leak. Currently mine is leaking on top at the intake manifold, my leak is minor but if it was bad it would run down the side of the engine.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
