WHEN THE CAR IS IN PARK and i rev the engine - FirebirdV6.com/CamaroV6.com Message Board
  • WHEN THE CAR IS IN PARK and i rev the engine
    there is like a whine sound the originates from the engine. anyone know what this is and how i can correct it?
    98 firebird V6<br />3.08 gears (3.42\'s coming sson)<br />free ram air (cai coming soon)<br />80 series flowmaster<br />more to come
    Gear drive?!? LoL That would be cool.. But I have that same sound, I can hear it at idle also, sounds like it is coming from the altenator..? Very odd.
    [*]<b>Car: </b>1991 CHEVY CAMARO RS<br />[*]<b>Engine: </b> 3.1lt (191ci) V6 - MPFI<br />[*]<b>Stereo: </b> Alpine 7995 H/U | Eclipse 21000 EQ | BOSS IQ 3000w Amp | Crossfire AB 400watt Amp | 3 AudioBahn 12\" D/V Subs | Planet Audio 4x6\'s & 6x9\'s
      it's proably from the free ram air mod.. it's just the sound of the motor sucking air..
      [ June 28, 2002: Message edited by: black98V6 ]</p>
      -Brad
      2000 V-Star Custom 1100
      :rock:
        a long screwdriver works wonderfully do diagnose a bad accessory shaft bearing (like alternator, etc).
        it also helps to rule out intake noise.
          yes, all you do is take the long screw driver, put it on the things in the engine, and put ur ear at the end of the screwdriver [img]smile.gif[/img] maybe someone put turbo when u were sleeping? :D
            maybe a blower :eek:
              Could be power steering pump going out, idler pulley bearings, alternator bearings, etc. Just use the screwdriver technique and you should find it.
                check out your belt and alternator. Clean your belt off or replace it and see what happens.
                1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
                  no, I get this too
                  I thought it was from my ram air intake rubbing against the radiator or something. I dont know what it is, but if you're in drive and just drifting forward and stick it in neautral you can get the same noise but at a higher RPM. I dunno, maybe the rev limiter. I have found that mine only makes the noise after I let off the gas, and the RPMs are decreasing from what the rev limiter holds them at.
