Got Smoke and Grinding/Knocking noises and I'm Scared - FirebirdV6.com/CamaroV6.com Message Board
  • Got Smoke and Grinding/Knocking noises and I'm Scared
    My car was getting a little hotter than usual so I changed my water pump last week. Everything was good til tonight. I'm driving and noticed that it was getting a little hot again. The gauge was almost at the 3/4 line. Then i'm driving and start hearing a loud metal knocking/grinding noise. What could the problem be? I checked my coolant, and it was hot. Had some smoke comming from somewhere when I checked under the hood. You can tell the Motor was hot. The grinding noise was only during idle in gear. As soon as i put it in N, it stopped. Then while in park, the rmp's were jumping like crazy. Could someone tell me what's wrong or what could I do?
    1997 Camaro RS Convertible<br />White w/black top, factory chrome rims <p>Mods so far: Borla catback, Catco high flow cat,CAI,2 point STB,painted calipers and drums with caliper camaro decals,GTS blackout all the around,5% tinted windows all the way around,Streetglow red neon lights inside and under, raised camaro fill in decals on the rear, 30th anv decals, and a nice stereo system<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=275528\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=275528</a>
    Check your oil. I say that, because I had a car (305) burn up all the oil, and spin two bearings. I'm thinking that you might have done that, or something similar, caused by oil starvation.
    The water would be hot because of the friction, and no lubrication. The smoke is probably coming from the valve covers, check there.
    I would guess that at this point, with that much noise, the motor's had it. If you drive it much more, it may very well seize up. Good luck with it.
