Redish spark plugs? - FirebirdV6.com/CamaroV6.com Message Board
Redish spark plugs?
  • Redish spark plugs?
    After going through a few bottles from spraying, I checked my spark plugs. They are a redish color. What does that indicate?
    Are you using an octane booster?
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      I have a few times. Is that what's causing it? I only use 93 octane too.
      Update: Like Dominic said, it's coming from using octane booster.
      [ August 03, 2003: Message edited by: shortdog273 ]</p>
        I don't have it in front of me but Haynes manual has a guide to what the spark-plug colors/condition mean.
        Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
          I've run Red Line Oil's injector cleaner and had it turn my spark plugs red.
            Wurd, injectr cleaners and octabne boosters always turn my tips kind of red.
              does injector cleaner really work? cause i think i have a clogged injector that is causing my misfire.
              what is the best brand? should i also get some seafoam as well?
              96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
                Sometimes when you run a very high octane gas or use a high octane booster with the 93 octane, it will turn your plugs red. Dont quite know why, but it is one way to check which of your cylinders may be running lean. The more red, the better. Shouldnt be anything to worry about.
                1995 Blue Chevrolet Camaro <br />Dynomax Exhaust, Custom CAI w/K&N, Throttle Body Bypass, ACDelco Plugs/Accel 8mm Wires. Indiglo Gauges. BMR Stut Tower Brace, ASP underdrive pulleys, BF Goodrich g-Force T/A KDW\'s around. <br />AIM: STMIKEK
