I'm about to install a 180 thermostat into my RS Camaro. Now when I go to put engine coolant back in, should I mix 50/50 water and engine coolant? I have the orange Dex cool because thats what the manual said to get but can I just pour that in or do I actually need to put in clean water as well? And usually how much fluid would I lose when taking the thermostat out?
Engine coolant question
<blockquote>quote:</font><hr>Originally posted by Lord_Verminaard:
Doesnt the 2002's already have a 180 thermo in it?
By the way, you'll probably only loose a tiny amount of coolant, you can just use water and it will be fine.
Brendan
2000 L36 M49<hr></blockquote>
All 4 gen F-bodies came with 195 thermos.
I would replace any lost fluid with Dex Cool.
[ August 06, 2003: Message edited by: John D. ]</p>2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
So our Tech Database is wrong? Thanks for clearing that up, I was originally not going to install one because I thought it already had a 180. Now I guess I will! [img]smile.gif[/img]
Brendan
Oh, wow.... I didn't realize the tech database called out the 98+ as having a 180 thermo. I would go with the tech database versus me
[img]graemlins/dunce.gif[/img] Sorry I gave bad advice, I WAS 100% sure on that till now.2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
Why would I need to drain it below the hose inlet?2003 Nissan 350Z Touring Coupe, Daytona Blue, Frost leather interior, navigation, 18 inch wheels, M6, fully loaded, intake, crank pulley.<br /><br />Previous cars:<br />1991 Mustang (347)<br />2002 RS Camaro<br />1985 IROC-Z (305)<br />1994 Camaro convertible V6
<blockquote>quote:</font><hr>Originally posted by John D.:
Oh, wow.... I didn't realize the tech database called out the 98+ as having a 180 thermo. I would go with the tech database versus me<hr></blockquote>
That's a known bug in the tech database.
Apparently it had 195 at one time, then some people said no,no,no it's 180, so it got changed.
But then later several of us pointed out that we had 195 stamped on our thermostats, and autotap reported exactly 195 degrees going down the road.
The tech database was just left as-is at that point.
The only exception to the 195 has been word-of-mouth that some hotter climate locations received 180 cars from the factory. But nothing that was across the board for a given year.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
<hr></blockquote>
NO, not all 4th gens came with 195 thermos. I have stock 180. MOST came with 195, but a few did come with 180. I'm not sure how to distiguish between them other than to take a temp reading.<a href=\"http://pics.projectpredator.com/thumbnails.php?album=16\" target=\"_blank\">2003 Zinc Yellow Mustang GT</a> 1 of 701<br />ET : TBD<br />But our shenanigans are cheeky and fun! Yeah, and his shenanigans are cruel and tragic. Which... makes t
<blockquote>quote:</font><hr>Originally posted by John_D.:
The only exception to the 195 has been word-of-mouth that some hotter climate locations received 180 cars from the factory. But nothing that was across the board for a given year.<hr></blockquote>
Ah, well that makes me feel a little better. I thought I was just making stuff up.
:D [img]tongue.gif[/img]2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
<blockquote>quote:</font><hr>Originally posted by Red94Camaro:
Why would I need to drain it below the hose inlet?<hr></blockquote>
Everytime I took that hose of i got a shower of coolant, maybe mine was overfilled.1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
Well when I take out my stock thermostat, should I just fill it it the coolant or do I actually have to make a 50/50 coolant/water mixture? And how much should it drain out?2003 Nissan 350Z Touring Coupe, Daytona Blue, Frost leather interior, navigation, 18 inch wheels, M6, fully loaded, intake, crank pulley.<br /><br />Previous cars:<br />1991 Mustang (347)<br />2002 RS Camaro<br />1985 IROC-Z (305)<br />1994 Camaro convertible V6
Refill with straight Dex.
Don't drain any out. Just do it when the car is cool. You will lose some when you pull the hose off, install the thermo, top off the radiator. Don't forget to bleed it off after your done.2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...9 hours ago
