Whenever I have my turn signal on, I have no clue if it is going to work anymore. Right or left, the blinker is very erratic. Sometimes there are 3 full second before two chimes, while sometimes it will do 12 in a row extremely fast. What is the error?
<a href=\"http://www.cardomain.com/memberpage/512325\" target=\"_blank\">2004 Silver Impala</a> Faster than my Firebird<br /><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=282862\" target=\"_blank\">3.4L Red 1995 Pontiac Firebird</a><b> For Sale</b>
ya most definatley your bulb...if your car was a bit older, might be your flasher....and hes definetly right about the melting, its so damn annoyting.....
So what do I need to do exactly? Sorry about this, but I kinda need a howto for things like this, since I am still a rookie, even if I am a postwhore. ;)
35 posts... i wouldn't call you a postwhore yet ;)
If it's just your left or right turn signal doing this, then it narrows down the bulbs you should check. If it's just the left side, check all your left signal bulbs to see if they're burnt out or have a bad connection. If it's boths sides, check all 4 corners. You have to come from under the car to access the front signals. first you take the air dam off that directs air to your radiator and then there is one plastic cover piece that comes off from each side then you should be able to see the signals. In the back, pull your interior carpet in the back well forward to locate the 3 (I think 3...) black plastic screws that hold your tail light assembly in on each side. unscrew them with your fingers and pull the light housing out. you should be able to take it from there.
1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
Has anyone used zzp gt1 cam if so is it worth the money and time
