all with autotap that know how to make gauge screen come up please help johnd slacker - FirebirdV6.com/CamaroV6.com Message Board
  • all with autotap that know how to make gauge screen come up please help johnd slacker
    Ok im talking about the screen that has the gauges that are blue, it shows a roun gauge with the actual rpm just like the real gauge on the car, and it shows a round gauge that has the mph and i guess when your driving the gauges will go up and down. how do i make this come up? and in the middle it shows the timing. if you go to www.autotap.com it shows a pic of a camaro at the top and it shows autotap hooked up to it, it shows the gauges screen. here is a link of the screen, how can i make mine do this?
    http://www.autotap.com/autotap_for_w...reenshots.html
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
    SLOWBREATHER, It is all in how you configure your screen just add a Guage and then pick the param for it then pick the range that you want to use and you can also pick the color that you want the guage to be. If you want I will hook mine up this weekend and take some screen shots for you let me know.
    Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
