can someone give me the exact method of doing this? I have a 94 3.4 Thanks.
fan switch for 3.4?
I did a search, but couldnt find what I was looking for. Found it for the 3.8 not the 3.4. Thanks for the site. Sorry bout that.My Car <a href=\"http://members.cardomain.com/tucsoncamaro\" target=\"_blank\">http://members.cardomain.com/tucsoncamaro</a> <br />3 inch flowmaster catback system, with ceramic coated pacesetter headers,3 inch cat,K&N FIPK
Re: fan switch for 3.4?
Linkie no workie.
This is what you get with a search.
Rob\"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
Just go ahead and save yourself the hassle of doing it yourself and worrying with loose wires/connections....buy the fan switch kit from SLP. Its only $75, and well worth it. The on/off switch is small enough that you could hide it in your ashtry if you want to...at least thats what I did.
The kit is a good buy, but if you have any electrical knowledge at all, you can install this yourself in under an hour and have no loose ends.
And as for your on/off switch, you can buy whatever kind you want, small or big.
But, if you do not have any type of electrical background, I would definitely purchase the kit and follow the directions very closely.
Originally posted by nascar24jdThe wire colors on the 3.4 are the same as the 3.8 as far as the electric fan goes.
I was not sure about the colors of the wires. The 3.8s have a high and low (one fan or two) so I figured it was wired differently.
I'll be doing it myself, I already have the switch and wire. I play with wiring all the time at work, alot of the rides have multiple potentiometers that go bad regularly.
I'm gonna try out my new Cold Heat. Also have to put in my Tranny temp gage.
The Cold Heat blows. I got my hands on it one time way back and it sucked
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
