Used 1/2 quart of oil in 1500 mi. - FirebirdV6.com/CamaroV6.com Message Board
  • Used 1/2 quart of oil in 1500 mi.
    I have a 97 Firebird 3800 with 102,000 miles on it and it uses about a quart of oil every 3,000 mi. No leaks ,gaskets have been replaced 2 yrs. ago. I know cars use oil but is this a little extream ?
    Thanks for any input
    97SILVERBID<br />Born to cruise
    1 qt every 3k miles isn't so bad. Probably a small piston-ring leak or valve seal leak, but really nothing to get worried about. If you start needing 1 qt a week, then it's time for some concern. ;)
      that seems like a bit much to me...the most ive ever had to add to my car between oil changes is MAYBE 1/4 qt and i have over 110K miles....id do a compression test to see if u have a ring leak or blown head gasket. hows ur coolant look? and is ur oil milky?
      1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
        Coolant and oil look normal. I'll have to watch it and see if it keeps using this much!
        Thanks
          im gonna recommend doing a compression test to see how good ur rings are sealing
          does ur car smoke any?
            No smoke
              I have 202,000 and still don't burn more than a 1/2 qt every oil change
              96 Firebird, Ram Air Hood and Airbox, Magnaflow Catback & hi-flow cat, Dynomax Bullet muffler
