Crankshaft positioning sensor - FirebirdV6.com/CamaroV6.com Message Board
  • Crankshaft positioning sensor
    The other day I heard a rattling coming from my engine bay, so when I got home I jacked up my car and saw that the crankshaft positioning sensor was rattling against the damper. It looks as though some plastic mounting piece broke. Temporarily I used a cable tie to keep it from rattling. Is this somthing should get taken care of right away?
    Yeah, the crank position sensor is pretty important. The car won't run right at all without it.
    2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      I had mine replaced at the shop...came out to 80 dollars for everything. My car would start to just turn off at random times. Get this fixed.
      1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
