Oil leak...from above... - FirebirdV6.com/CamaroV6.com Message Board
  • Oil leak...from above...
    Help me solve this- I can't figure out where exactly it's coming from, but its leaking from above the tranny/oil pan and coming down...I think it may be the valve seals?
    What else could it be?
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
    Don't think it would be your valve seals...if it was, you would get oil leaking into your combustion chamber and you would be blowing black smoke.
    Try the back of the intake manifold which seals the lifter valley or the valve cover gaskets.
      My vote is for rear main seal, it's pretty notorious on the 3.8 series 2
        blah ignore my posts.. the things I think dont come out in the things I type
        [ November 12, 2002: Message edited by: 93v6firebird ]</p>
          i would go with a rear seal or valve cover gaskets to
          <a href=\"http://www.redlinevsix.com/\" target=\"_blank\">RedLineVSix</a><br />98 NbM Camaro M5
            Rear main seal in not above the tranny.
              My car has the same thing and it is the rear main seal i can assure you.
                my 3.4 has a pain in the *** oil leak also. I removed the torque convertor cover and found a plate with 3 bolts right above the rear main seal.I believe its for the camshaft.I dont know if the 3.8 is the same but thats where my leak is coming from!!
                  Check this out:
                  http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=007142
                  ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                  • 187shark
                    by 187shark
