What would happen if you ran no thermostat? Is there a sensor that detects the flow of water? How does the PCM know if the stat is open,closed or gone? Can your PCM be tuned for no stat?
Running No Thermostat
having no thermo will keep your PCM in open loop longer because it will take longer to reach operating temps. staying in open loop will not allow your vehicle to run at peak abilities because during open loop, your PCM controls everything based on predetermined programing and keeps your a/f ratio alittle rich
[ June 12, 2005, 08:45 PM: Message edited by: BLLDOGG ]
I've considered doing this, and what I'd have to do is put a pulse width modulator on my e-water pump to control the speed. I think it would be pretty effective. But if you're still running a belt-drive water pump, it wouldn't be good.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
