GT or VS cam - FirebirdV6.com/CamaroV6.com Message Board
GT or VS cam
  • GT or VS cam
    Ive been reading through past posts on cam selection and havent found any decisive conclusions about pros or cons of any of the cams out there. I was thinking about getting the Comp Cam GT cam. ZZPerformance claims no SES light, but after reading posts it sounds like most of the people using it do get a code. Im now leaning toward the VS cam and cant find anyone that has it.
    Specs :
    206/216 .512/.507 lift 115LS/113IC
    will probably be the last of my mods unless I *perhaps* get a small shot of nitrous somewhere down the road. complimenting mods will include Headers, exhaust, gears and intake. I want something with more low end with power in the 1000-4000 rpm range that isnt too radical and wont set an ses light.
    Any thoughts?
    [ February 05, 2004: Message edited by: ellik ]</p>
    \'01 Mineral Grey SVT Cobra<br />-former F-body owner
    I have the VS cam, check out my site, link in the sig. Yes it does throw an ses light mostly for random misfire and system to lean bank 1 and 2. I love it though I just keep my code scanner with me at all times.
      I asked something like this a while back and was told the VS is a forced induction cam.....
        its a N2O cam but can be used for FI. Still very good NA, like I said I love mine.
          since were on the subject of the VS cam.
          why does it set a lean condition code?
          00 Camaro with the Y87 Package!<br /><br />stock times 15.59 @86.3mph with a 2.25 60\'
            zzp claims it doesnt set the ses, but they say that about the gt cam as well. anyone put the gt cam in and get the ses light?
            if it happens that both set it off, i think I'll go with the VS and remove the SES light.... I think ive seen a write-up on that somewhere.
              I get a light with my GT cam.
              1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
                <blockquote>quote:</font><hr>Originally posted by ellik:
                <hr></blockquote>
                dont take out you ses light lol
                www.turbov6camaro.com
                1997 3800 Series II Camaro
                  The SES light on the GT cam, is caused by false knock, all you have to do is desensitize your knock sensors with a resistor. Do a search in the Advanced tech forum, or check out Seppo's site he has all of this information detailed there.
                  2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
                    i have the VS cam and i get no random misfires or any ses lights.
                      Hmmm.... sounds like its a hit or miss thing then.
                      ZZP shows more potential gain with the VS cam, but that seems to be when combined with nitrous or SC. Since I'm not going radical with mods im guessing I'll probably see quite simialar improvement with either one. Am I correct that with the GT's 112LS I will see a slightly lower power band than the 115LS of the VS cam, which is what I am shooting for?
                      will the resistor trick work with the VS cam also if I go that route and get an SES?
                        I put as resistor in and the only codes i got then were iat module to low but I havent check in a while.
                          <hr></blockquote>
                          115 LSA will give you a much longer torque curve then the 112 LSA, and peak torque will bue a higher RPM on the 115, up too you
