put in o2 sim... how to get rid of ses light? - FirebirdV6.com/CamaroV6.com Message Board
  • put in o2 sim... how to get rid of ses light?
    i pulled the fuses for the pcm, then pluged in my o2 sim, but qhen i got done, and after waiting about 15 minutes to plug the fuses back in, the ses light is still on. how do i get rid of it?
    <a href=\"http://www.cardomain.com/memberpage/325081\" target=\"_blank\">1998 Red Firebird M5</a><br />not enough mods
    Assuming the SES is caused by a P0420 code, just run the car a few times and it'll clear it automatically. It should clear after 3 full run cycles.
    Matt
    1998 Mystic Teal Camaro M5
      or just drop by Auto Zone to have them check it cause that way they will clear it [img]smile.gif[/img]
      2000 3.8 A4 Pewter Camaro
        you had a front 02 code right? you only put the sim in AFTER the converter right?
          i had a post cat o2 code... i replaced the front o2's about a month ago
