help me please - FirebirdV6.com/CamaroV6.com Message Board
help me please
  • help me please
    my camaro has been having touble idling.. yesterday morning it cut off at a light like 3 times then like times 2 turning around to go home.. my friend said it was cuz my engine was cold but i would always drive it like that and it would never happen, then while in my evening class one of the guys in there said his friend had a 98 camaro and he said my idle might be to low and that i can manualy change that... idk but im in need of some help. thanks
    Is it running to rich or lean? Can you smell gas STRONGLY from the exaust? Any other problems, bogging, trouble at WOT, etc etc? What year Camaro? What motor?
    2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
    1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
    1974 Silver Chevrolet BIG BLOCK Corvette
        Are you getting a check engine light?
          nop
            sounds like vacuum to me. check all vacuum lines, be removing them one at a time and checking the seals.
            i found the problem on my friends car and it was a kinked hard plastic hose, i brok it and put a new tube on the broken spot and it idles alot better. check your fuel filter and plugs those will be cheap. wires as a stock replacement ar $15 filter $10 or less and for regular plugs $12. but, yeah we need to know more about how it drives does it studder then or what or is it just strictly idle. i bet if you turn your AC on and turn your wheel at idle you engine will bog and die especially while its in gear.
            chang the things above since these are maintenance anyway and get new o2 sensors.
            o2 sensors sound like your problem. unplug your passenger side o2 sensor and see if your car idles a little better. i bet it will. i would replace your o2s if i were you
            how many miles on your car, is it auto? Is it running to rich or lean? Can you smell gas STRONGLY from the exaust? Any other problems, bogging, trouble at WOT, etc etc? What year Camaro? What motor?
            please answer all of the questions in the previous paragraph and it will help us help you. good luck
            i would go to schucks or autozone and scan it anyway to see what things trouble codes it may have had before, you might be suprised at what things you have wrong with your car.
            96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
              ok heres the new deal... got my car "fixed" put in 2 new o2 sensors, maf senser, catiltac convertors, and some throttle thingy..id remember whats its called .. iknow i know sorry.. but it started runing like normail but now it sounds like its backfiring...whenever i get up on the gas it might pop or it will feel like someone is taping the breaks like 4or 5 times in a quick time.... me not knowing alot about cars i am thinkgin it might be something wrong the a cyclinder... or maybe a spark plug or idk... thanks for the help
                it was the spark plug so im good now
                  Now...find out why the spar plug went out on you, and you'll be set.
                    HAHAHAHAHA I know that feeling when you think your car is about to grenade. a few days ago I was *testing* my new suspension setup and all of a sudden the car would barely run and sounded like it would explode at any moment. at idle the car would shake really bad and if in gear even with my foot on the brake slightly it would jump forward. 20 minuets later I get it home and start looking and the #2 spark plug wire had come off the coil pack. talk about a sense of relief
                    95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
                      I've had the same thing twice, and both times one of the plug wires was being fried by the engine.
                      1996 3.8 Firebird with some mods
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
