Blinkers - FirebirdV6.com/CamaroV6.com Message Board
Blinkers
  • Blinkers
    Hey guys, my blinkers on my '93 firebird dont work. The lights in them still work, so i'm guessing its a relay or fuse. Where are the relays located? or what else could it be? Any help is appreciated, but i've been driving around without them for about a year ;)
    Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
    If you activate your turn signal, and the green dashboard arrow stays lit, then you have a bad bulb on the exterior turnsignals.
      well, are you sure the lights in them still work? what are the symptoms. do they turn on low light when the lights are on? do they light up steady or at all when the blinker is turned on? One thing to consider is turn signal bulbs have two filaments, kinda like having two bulbs there. so either that your rear signal lights are out. or incase thats not it, your turn signal relay is located under your steering column to the right side, behind the kick panel, two 10mm bolts hold it on underneath then it clips off, you'll find it there. if thats not enough search for it and you'll find it. I am basing the relay location off my 00' so dunno.
      05' CTS-V
      00' Camaro - SOLD :(
        Checked the blinker fluid lately?
          hey check out its relay under the dash. it looks like a silver cylinder. get to it, pull it out, a put a new one in for like $2. your problem should be solved. nothing to it.
