Does anyone know where the actuators for the HVAC controls are located? No matter which setting I set the HVAC on (face, floor, face and floor, defrost, etc), the air only comes out of the floor and winshield outlets. I know it's a vacuum problem. And without actually putting a vacuum on my HVAC lines, I'm pretty sure it's the actuators. More precisely, I think it's the Bi-Level and Upper and Lower Mode actuators. But, I have NO idea where they are. Any help would be appreciated.
Try this link to shoebox's site. The vacuum lines on the z28 are going to be a little different but not as much as you'd think. I'm pretty sure the check valve is in the same spot. I had the same problem, I fiddled with the check valve for about 2 minutes, and its better although not there yet.
