ok at half throttle i can hear a whistling sound from my drivers seat. if i push it down or let off it goes away....what is that?
vacuum leak??????
yeah seems like something is clogged or somethin???? sometimes it runs awesome and sometimes i can floor it and i'll just bog or sorta flood out or something
but definately not the power it sometimes has
Makes me mad and i wanna kick the gas pedal through the floor when i floor it
EDIT:but if i floor it then let out a little it takes off and flies....it's driving me nuts!
[ May 01, 2002: Message edited by: uno ]</p>1993 240sx 5 speed, Super Hicas, LSD, Stock for now<br />Sold-1995 Red T-Top 3.4 Camaro<br />Totaled-1997 Jade Green Cavalier 2.2 auto
same problem... sorta...
anyone know what's wrong?<b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
Sounds like a vacuum line fell off or you have a leak in your intake. Those damn EGR valves are usually the culprit for an intake leak. Put some water in a spray bottle and squirt it all around your intake while the car is running. If you hear the RPMs go up, you've found it.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
just curious, but how does spraying water on a faulty EGR make the RPM's go up? does it clog it or something???<b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
<blockquote>quote:</font><hr>Originally posted by SuprSpdDB7:
just curious, but how does spraying water on a faulty EGR make the RPM's go up? does it clog it or something???<hr></blockquote>
Yeah, you're right. I have carburetor on the brain. I think it will actually make the RPMs go down for a second because the water will fill the gap before it gets sucked in. Doesn't matter what happens to the RPMs, just look for a change. This isn't to check for a faulty EGR, it's to check for intake leaks at the gaskets. Carb cleaner will do the same thing, but that stuff is expensive.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
dont use a spray bottle of water, use some carb and choke cleaner, also, yeah, my car is misfiring, and on the scanner, im getting no readings from the EGR valve, and on the manual it said to check to see if its working, my car is having the same problem, so i think that is the culprit, new EGRs are expensive, and in my area all parts stores have to order them.97\' Black Firebird W68<br />mods as of yet- home depot CAI, Dynomax exhaust, 255 Yokohama tires
