Please help! Water pump pulley removal?! - FirebirdV6.com/CamaroV6.com Message Board
  • Please help! Water pump pulley removal?!
    I can't seem to figure out how to remove the water pump pulley on my 3.8L firebird. I've searched and searched and still am not sure what/how I need to remove it.
    Thanks!
    Hmm, I finally found that an adjustable oil filter wrench will hold the pulley in place. I got two of the bolts off but the other two have rounded off.
    FCK!!! Sparying anti-whatever bolt looserner now
      That didn't work... taking a hacksaw to the remaining bolts tommorow. Blech.
        you know, there is a tool for that exact job that would have saved you all that trouble [img]smile.gif[/img]
        goofy-*** do it yourselfers [img]tongue.gif[/img]
        2000 3.8 A4 Pewter Camaro
          Would you mind linking me to it? A normal pulley remover won't work on the water pump because it's pressed/bolted on (And not in the center either).
